Home > Think Tank > How to Disable Contents Indexed Feature on a Drive
Jul 4, 2025
The Contents Indexed feature in Windows allows the operating system to index the files on your drive to speed up searches. However, this feature can slow down performance, particularly older machines or drives with limited resources. Disabling it can improve system performance or reduce unnecessary drive activity.
What does "Allow Files on This Drive to Have Contents Indexed" do?
When this option is enabled, Windows Search indexes not just file names but also the content inside documents, PDFs, emails, and other files. This can be helpful for searching text within files but may lead to:
  • Increased disk usage
  • Longer indexing times after large file changes
  • Slower performance on older or HDD-based systems
Steps to disable Content Indexing on a drive
Follow these steps to turn off this feature for a specific drive:
Step 1. Open File Explorer
Press Windows + E to open File Explorer.
Step 2. Locate the drive
Find the exact drive you want to modify on the window of This PC (e.g., C:,/ D:).
Step 3. Open drive Properties
Right-click the drive, then click Properties.
Step 4. Uncheck the Indexing option
In the General tab, look for the checkbox for Allow files on this drive to have contents indexed in addition to file properties and ensure to uncheck it.
Step 5. Apply the change
Click Apply, and then choose the second option when the Confirm Attribute Changes dialog box appears. You may also need administrator privileges to make this change.
Step 6. Wait for the process to complete
Windows will begin removing the indexing attributes from all files and folders. This may take a while depending on the size and number of files on your drive. Once the process finished, click on OK to exit.
Important notes
  • Some system files or folders may not allow changes and will be skipped.
Disabling the contents indexed feature on a drive can help optimize performance, especially for drives that do not benefit from search indexing. If you prioritize performance over fast file content search, turning off this feature is a simple and effective tweak.
How to Fix Taskbar Icons Not Showing on Windows 11How to Fix Photoshop Crashes on WindowsHow To Disable Keyboard Or Mouse From Waking Up Computer In Windows 11
