Home > Think Tank > How to Fix Office Application Error 0xc0000142
Jul 8, 2020
Sometimes, when we try to start an Office application (such as Word, Excel, Outlook, etc.), we could see "Updating Office, please wait a moment." After a few minutes, it will display "WINWORD.EXE - Application Error. The application failed to start correctly (0xc0000142). Click OK to close the application."
updating office
word error 0xc0000142
If you have the same problem, don't worry about it. It is very easy to fix this issue.
Please open the Task Manager, switch to Services, find ClickToRunSvc, right-click on it, and select Restart.
fix error 0xc0000142
Done! You can start the Office as usual.
How to Install a macOS in VMware Workstation PRO 17How to Enable Task Manager Option in Taskbar Menu on Windows 11How to Turn On The System Restore of Windows 10
