Registry Defrag
Wise Care 365 can analyze and compress redundant registry fragments. A clean and tidy registry can effectively increase the speed of the system.
Please save your work before the registry defrag, the system will lose response for a few minutes during the registry analysis. Registry defrag requires a system restart. Do not use any method to interrupt the registry defrag, otherwise it will cause a serious system failure.
1. Analyze the registry status
Wise Care 365 will first analyze the system's registry to determine whether the registry needs to be defragged. During the analysis, the system will lose its response for a few minutes, don't worry.
2. Defrag the registry
After the analysis is completed, click the [ Defragment ] button, Wise Care 365 will prompt the user to restart the system.
