Advanced Cleaner
Scan and clean specific types of files in the specified locations.
1. Select the locations that need to be scanned
To the right of the scan location, click the down arrow to expand the list of drives and select the drives that need to be scanned. All available drives are selected by default.
2. Select the file types that need to be scanned
Wise Care 365 finds and cleans files in the specified disk by default: *.tmp, *.temp, *.chk, *.gid, *.dmp, and so on, total 22 types of files. And other 21 types of files that can be selected for cleaning. You can click the [ Advanced Settings ] button in the lower right corner of the window to open the settings window and select the file type that needs to be cleaned.
At the same time, you can also click the [ Add ] button to add other file types that need to be cleaned up.
Before adding a file type that needs to be deleted, please double-check whether the file of this type can be safely deleted. After the file is deleted, it cannot be recovered. For ordinary users, please do not use the Add function! It is recommended to use the recommended settings!
3. Select the files that need to be deleted
After the scan is complete, the scan results are sorted by location by default. You can also click the title bar to reorder, for example, click the File Name, the list will be sorted by file name; click the Size, the list will be sorted by file size. The list also will be sorted by File Path, file Last Accessed time, and File Type.
: It means that this file can be safely deleted.
: It means that Wise Care 365 cannot judge whether this file can be safely deleted, It is up to the user to decide whether to delete it.
: This mark indicates that this file is a file type added by the user in the Advanced Settings or a file in a custom folder added in the Menu -> Settings.
Right-click on an item, you can call out the context menu.
Ignore this item
Add this file to the Exclusion list, Wise Care 365 will neither scan nor clean it again. You can view the content of exclusion in Menu -> Settings -> Exclusion.Select All
Select all files.Select None
Do not select any files.Invert Selection
If you just don't want to delete a few files, you can select these files first, and then use the Invert Selection function, you can quickly select other files which need to be deleted.Open Containing Folder
Open the location of the selected file.Export to ...
Export and save the scan results as a text file.
4. Custom Folder
Advanced Cleaner also supports emptying all files in the specified folder. You can add the folder which needs to be emptied in Menu -> Settings -> Cleaner.
Note: This is to empty the folder, not to clean it. Advanced Cleaner will only empty all the contents of the folder!!!
