System Requirements of Wise Duplicate Finder |
Wise Duplicate Finder will run on any PC running Microsoft Windows XP or later. If you're running one of the following operating systems, it's OK to run Wise Duplicate Finder:
Windows 10 (All Windows Editions, including both 32-bit and 64-bit)
Windows 8 (All Windows Editions, including both 32-bit and 64-bit)
Windows 7 (All Windows Editions, including both 32-bit and 64-bit)
Windows Vista (All Windows Editions, including both 32-bit and 64-bit)
Windows XP (All Windows Editions, including both 32-bit and 64-bit)
Since Wise Duplicate Finder is a small and quick program, it takes less memory and needs fewer hard drive requirements.
P.S. Wise Duplicate Finder does not currently support Mac OS or Linux.
Copyright 2006-2016 WiseCleaner.com All Rights Reserved.
