Home > Think Tank > How to Fix Battery Not Detected Errors
Jul 1, 2026
Seeing a "No Battery is Detected" error on your Windows laptop can be frustrating, especially when you rely on battery power while away from an outlet. This issue may prevent your laptop from charging properly or cause inaccurate battery status readings. Fortunately, there are several troubleshooting steps you can try to resolve the problem.
What Causes the Battery Not to be Detected
A battery detection issue can occur due to:
  • Loose battery connections
  • Outdated or corrupted battery drivers
  • BIOS or firmware issues
  • Power management glitches
  • Hardware problems with the battery or motherboard
  • Recent Windows updates causing driver conflicts
Method 1. Perform a Power Reset
A power reset can clear temporary hardware glitches that prevent Windows from recognizing the battery.
  • Shut down your laptop completely.
  • Disconnect the power adapter.
  • If the battery is removable, remove it.
  • Press and hold the Power button for 15–30 seconds.
  • Reinstall the battery and reconnect the charger.
  • Turn on the laptop and check whether the battery is detected.
Method 2. Check Battery Connections
If your laptop has a removable battery:
  • Turn off the laptop.
  • Remove the battery.
  • Inspect the battery contacts for dust or debris.
  • Clean the contacts carefully with a dry microfiber cloth.
  • Reinsert the battery securely.
  • Ensure the battery connector is properly seated.
Method 3. Reinstall Battery Drivers
Windows uses battery drivers to communicate with the battery hardware.
  • Press Windows + X and select Device Manager.
  • Expand Batteries.
  • Right-click Microsoft ACPI-Compliant Control Method Battery and select Uninstall device.
  • If available, also uninstall Microsoft AC Adapter.
  • Restart your computer.
  • Windows will automatically reinstall the necessary drivers during startup.
Method 4. Update BIOS or Firmware
Laptop manufacturers often release BIOS updates that improve battery detection and power management.
  • Visit your laptop manufacturer's support website.
  • Search for your laptop model.
  • Download the latest BIOS or Firmware update.
  • Follow the manufacturer's installation instructions carefully.
Note: Interrupting a BIOS update may damage your system, so ensure the laptop remains connected to power during the process.
Method 5. Check Battery Health
A worn-out battery may no longer communicate properly with the system. To generate a battery report:
  • Open Command Prompt as Administrator.
  • Run the following command:
powercfg /batteryreport
  • Open the generated report and review the battery's design capacity and current capacity.
Note: If the battery health is significantly degraded, replacing the battery may be necessary.
Method 6. Test with Another Charger
A faulty power adapter may cause charging and battery detection issues.
  • Verify that the charger is the correct model for your laptop.
  • Check for damaged cables or connectors.
  • If possible, test with a known-working charger.
Method 7. Replace the Battery
If none of the above methods work, the battery itself may have failed.
Common signs of battery failure include:
  • Battery not detected consistently
  • Laptop shuts down immediately when unplugged
  • Battery percentage fluctuates unexpectedly
  • Battery fails to charge
Note: Replacing the battery with a genuine manufacturer-approved replacement is usually the best solution.
A "Battery Not Detected" error is often caused by driver issues, temporary power glitches, outdated firmware, or battery hardware problems. Start with simple solutions such as performing a power reset and reinstalling battery drivers before moving on to BIOS updates and hardware inspections. If the battery health report indicates severe wear, replacing the battery may be the most effective long-term fix.
Windows 11 Battery Saver vs. Energy Saver: What's the Difference?How to Disable the IP Helper Service in Windows 11How to Enable or Disable Audio Enhancements in Windows 11
