Home > Think Tank > How to Fix iPhone Brightness Keeps Changing
Dec 26, 2025
Some iPhone users report that their screen brightness seems to fluctuate on its own: sometimes getting too dim in bright daylight, at other times suddenly blindingly bright indoors. While Apple’s automatic features are designed to optimize comfort and battery life, they don’t always behave exactly as you’d like. Below is an easy-to-understand guide that tells you the reason and what you can do to stop it.
Why Your iPhone Brightness Changes Automatically
1. Auto-Brightness. It can monitor ambient light via the front-facing sensor, then adjust brightness accordingly in bright environments and lower it in dark environments.
2. True Tone. Adjusts the screen’s color temperature and intensity to match the ambient light's color. This can make your screen appear warmer (more yellow/orange) or cooler (more blue).
3. Night Shift. Shifts colors toward the warmer end of the spectrum after sunset to reduce exposure to blue light. Typically activates on a schedule or at dusk.
4. Low Power Mode. It automatically reduces screen brightness when the battery falls below a threshold.
5. Software Bugs. iOS glitches, app conflicts, or background processes can occasionally override your chosen brightness.
Disable Auto-Brightness and True Tone
Auto-brightness and True Tone are the most common reasons that cause brightness to change automatically on an iPhone. You can turn them off in the Settings app.
1. Open Settings > Accessibility.
2. Tap Display & Text Size
3. Scroll down to find and turn off Automatic.
4. Under the BRIGHTNESS section, toggle True Tone off.
 Disable Auto-Brightness and True Tone in Settings.
Adjust or Disable Night Shift
If your iPhone keeps switching to a warmer color at a specific time of day, it might be due to a Night Shift schedule. Head to your device settings to disable it.
1. Open Settings > Display & Brightness> Night Shift.
2. Turn off the Scheduled option.
 Turn off the Scheduled option in Night Shift.
Confirm Low Power Mode Status
The Low Power Mode reduces your iPhone’s power consumption when the battery is low. When enabled, the brightness of your iPhone will dim even if Auto-brightness is turned off.
1. Open Settings > Battery.
2. If Low Power Mode is on, tap to turn it off (or charge your phone above 80%).
 Turn off Low Power Mode.
Check Attention Aware Features
Attention-Aware features on your iPhone can automatically dim your iPhone’s screen when it detects that you aren’t looking at it. To prevent it, access the Face ID settings on your device and turn it off.
1. Open Settings > Face ID & Passcode.
2. Scroll down and disable Attention Aware Features
 Disable Attention Aware Features in Face ID & Passcode.
Reset All Settings
Lastly, if these methods above don’t work, reset all settings on your iPhone to fix this issue, which does not erase your data, but resets system settings (Wi-Fi, Display, Privacy, etc.).
Go to Settings > General > Transfer or Reset iPhone > Erase All Content and Settings> Continue.
 Reset All Settings in Transfer or Reset iPhone section.
FAQs
Q1. Will disabling Auto-Brightness shorten my battery life?
Potentially yes. A fixed high-brightness level can consume more power in dark environments. Try finding a comfortable manual setting.
Q2. Does True Tone use extra battery?
Only minimally. It adjusts temperature and brightness in real time, but its power draw is very low.
Q3. My iPhone still randomly changes brightness after all these steps. What now?
Back up your data, then consider a full erase and restore via Settings > General > Transfer or Reset iPhone > Erase All Content and Settings. If the issue persists, contact Apple Support for a hardware check.
Most brightness-fluctuation complaints on iPhone trace back to settings like Auto-Brightness, True Tone, Night Shift, or Low Power Mode. In most cases, simply toggling those features off, along with keeping iOS updated, will return you to a stable, user-controlled brightness level. If problems continue even after resetting settings and ruling out software bugs, seek professional help to check for hardware damage.
How to Enable or Disable Inactive Scrolling in WindowsHow to Adjust Refresh Rate in Windows 11How to Enable Voice Access in Windows 11
